We understand what it’s really like to live with pets — and what a truly pet-friendly robot vacuum should be able to do.
The DuoDivide™ main brush system (SGS-certified) guides hair directly into the suction inlet for immediate pickup. No more cutting hair tangled in brush with scissors.
HyperForce™ suction reaches deep into carpets to lift pet hair, dust, dander, and even particles like cat litter.
Pet hair tends to collect along edges and in corners. The FlexiArm™ side brush automatically extends to sweep hard-to-reach areas more thoroughly.
Pets naturally bring home dirt, dust, and germs after outdoor activities. Roborock uses up to 80°C hot water mop washing to help dissolve stubborn stains and greasy buildup, followed by warm-air drying for improved mop hygiene and freshness.
Reactive AI system can recognize pets and automatically slow down or stop the brush system when needed. It can also identify and avoid 280+ types of common household objects, including unexpected pet messes, to reduce cleaning accidents.
Miss your furry friends while you're away?Use the app for real-time video calls and remote interaction: check on your pets anytime, track your pet, remotely guide your robot to any spot for a closer look.
Discover Roborock robot vacuums designed for pet-friendly homes — combining powerful suction and efficient mopping to handle shedding with ease.
The Smartest Pet Companion
Up to 36,000 Pa suction power
Real-time video calls and pet search
Low-clearance navigation down to 7.95cm, reaching under beds and sofas
Ideal for Sensitive Homes
25,000 Pa deep-cleaning suction
Up to 80°C hot water mop washing and 55°C warm-air drying to help reduce odors
Filters up to 99.5% of dust, allergens, and fine particles
Best for Muddy Paw Prints
SpiraFlow™ system helps mop with cleaner water throughout cleaning
2.5X boosted mopping pressure to easily tackle muddy paw prints and wet messes
Intelligent dirt detection for re-wash and re-mop
Built for Hair Management
DuoDivide™ main brush with 0% hair tangle
Extendable mop reaches closer along edges and corners
Auto-empty dock offers up to 7–9 weeks of hands-free dust collection
See how pets react to their newest household companion
1. Will a robot vacuum scare my pets?
Not usually. Select Roborock models include pet-friendly features that can automatically slow down or navigate around pets when nearby, helping reduce sudden bumps and noise disturbance so pets can adapt more comfortably to daily cleaning.
2. What if my pet has an “accident”?
Roborock robot vacuums equipped with Reactive AI can recognize common obstacles such as pet waste and respond differently based on the cleaning mode. Whether avoiding solid messes or handling liquid stains during vacuum and mop cleaning, they help reduce cleaning hassles and make everyday maintenance easier for pet households.
3. Can it handle long pet hair?
Yes. Most Roborock models feature the DuoDivide main brush system, designed to help manage hair more effectively. Its dual-roller structure guides hair toward the center suction inlet during cleaning, helping minimize tangling and reduce manual brush maintenance. It can achieve 0% hair tangle performance under tested conditions and is SGS-certified.
4. Can it help with allergies?
Yes. Roborock powerful suction helps remove pet dander, hair, and hidden dust from carpets and floors. HEPA filtration and high-efficiency dust bags help capture fine particles, with dust bag filtration efficiency reaching up to 99.5% for particles as small as 0.05 μm, helping reduce airborne dust and pollen particles.
5. Can it clean muddy paw prints?
Yes. Roborock robot vacuums use consistent downward mopping pressure to help remove muddy paw prints and everyday floor stains brought in by pets. The Roborock Qrevo Curv 2 Flow features a real-time self-cleaning mop system that continuously refreshes clean water while collecting dirty water during mopping, helping keep the mop cleaner throughout the cleaning process.
6. Can I check on my pets while I’m away?
Absolutely. Some premium Roborock models can do more than clean floors — they can also act as mobile home assistants. Using the app, you can remotely check your home, drive the robot to look for your pets, and enjoy two-way voice interaction to stay connected even when you’re away.
