Roborock F25 Ultra
Steam On, Stains Off
The industry-first1 wet & dry vacuum cleaner of its kind, featuring two powerful high-temperature cleaning modes: steam and hot water.
Industry First2
VaporFlow™ & WaveFlow™
Engineered for Stubborn Messes & Hygienic Cleaning
Elevated Power
Impeccable One-Stroke Wet-and-Dry Cleaning
JawScrapers
Zero-Tangle & Streak-Free3 Cleaning Experience
Seamless and Upgraded Maneuverability
FlatReach™ 2.0
Reaches Deep Underneath
Smart Self-Cleaning
& Drying Roller
Stays Clean and Ready to Roll
Intelligent App
and Voice Alerts
Sticky or Greasy?
Let the Heat Break It Down.
VaporFlow™
Dried Stains? Blast Them Away with Steam.
Tackle dried-on messes and stubborn stains with high temperature steam sprayed across a full cleaning width — No chemicals needed.
180°C/356°F
Consistent Steam4
2,000mg/min
High-Volume Steam5
6
Steam Outlets
48°
Optimized Outlet Angle
≥99.99%
Bacteria Removal Rate6
≥99.9%
Allergen Reduction Rate7
Steam Cleaning Mode -
Certified by TÜV SÜD: In steam cleaning mode, the test simulated 5 years of cumulative use (18,000 strokes). The solid wood floor surface showed no swelling, no wrapping, and no cracking - delivering powerful cleaning with total floor safety.
Report No.: 704012500497-01
WaveFlow™
Breaks Down Grease. Clears Away Slime.
Dissolve greasy buildup in both the kitchen and dining room with continuous hot water—tough on messes, gentle on floors9. Built-in nonhazardous10 descalers box and filter prevent scale formation and protect pipes from clogging for up to 3 years11.
86°C/187°F
Running Hot Water12
Cooking Oil Removal Rate13
3-layer
Anti-Scale Structure
32 Outlets
Evenly Heat the roller
From Deep Power,
Down to the Details
Next-Level Wet & Dry Cleaning,
Right Down to the Edges
Enhanced suction power removes daily wet and dry messes in a single stroke.
22,000 Pa
Suction Power14
33N
Downward Cleaning Pressure15
<1mm
Edge-to-Edge Cleaning16
<1mm
Blue Light Illumination
See the Mess You Used to Miss
Illuminate hidden dust and fine particles for a clearer view and more confident cleaning.
Built for the Long Haul
Up to 60min
Battery Life (Auto Mode)17
Up to 500 sqm
Cleaning Area per Charge18
1,000 ml
Clean Water Tank
Built for Hassle-Free,
Tangle-Free Performance.
JawScrapers Roller
Engineered for Tangle-Free Experience
Achieve flawless, water streak-free19 floors with the dual anti-tangle scraper roller—featuring a constant-pressure scraper to prevent watermarks and shark-tooth blades that capture hairs for a perfectly smooth finish.
Tangle Rate20
DirTect® Smart Sensor
Smart Innovation,
Superior Clean
The smart sensor monitors dirt levels in real time, automatically adjusting cleaning intensity for optimal results across different surfaces.
Cleaning Level
Dirt Level
Auto Detergent Dispenser
Smart Innovation, Superior Clean
Enjoy up to 3021 days of cleaning with a single detergent refill. The auto dispenser intelligently releases family-safe22 detergent as needed, enhancing cleaning performance.
30
DAYS
Handles the Mess,
So You Don't Have to
Featuring a detachable wet-and-dry separation module in the dirty water tank, maintenance has never been easier.
Moves as
You Move
Glide Smoothly with AI-Enhanced SlideTech 2.0
Enhanced with dual brushless motors that independently control each wheel, SlideTech 2.0 delivers ultra-smooth maneuverability with millisecond response times—making tight turns effortless, whether pushing or pulling.
Small Tweak,
Big Improvement
With a lowered tank and 70° swivel, it glides effortlessly around furniture and obstacles for faster, easier cleaning.
FlatReach™ 2.0
No Spot Missed, Especially Under Furniture
Power through tight spaces with a slim 12.5 cm flat design that maintains full suction at 180°. Its ultra-low profile reaches every corner, leaving no dust behind.
12.5 cm
Body Height
180°
Lay Flat
12.5 cm
Body Height
180°
Lay Flat
12.5 cm
Body Height
180°
Lay Flat
Tap and Glide Effortlessly into Tight Spots
Use the app to steer the device right under beds or sofas—no bending needed.
Self-Cleaning You Can Trust
Using steam and heat flow to deep-clean the roller with advanced solid-liquid-air separation technology, while the DirTect® module senses dirt levels and automatically adjusts the cleaning power—keeping the roller fresh and spotless.
180°C
/356°F
Steam Self-Washing23
90°C
/194°F
High Temperature Self-Washing24
≥99.99%
Bacteria Removal Rate25
Multiple Stages
Separation System
Dries the Way You Like
95°C/203°F26 Hot-Air Self-Drying
5-min27 Fast Drying
Ready to clean again, instantly.
30-min Quiet Drying
≤53 dBA28 — No Disruption
Intuitive Design.
Customizable Features.
One-Touch
App Customization
Personalize the Cleaning Settings
Set every detail to match your home and habits.
Scheduled Self Cleaning & Drying
Clean and dry on your schedule — without disrupting work or rest.
Tank Alerts, So You Don’t Forget
Stay ahead of smells and cleaning delays with smart alerts.
On-Screen Status Display
Easily monitor key settings and live progress with a clear, intuitive display.
Voice Alerts
Receive real-time notifications and updates through convenient voice alerts, keeping you informed at all times—without the need to check the device manually.
*Images and videos are for illustration purposes only and may not precisely represent the actual products. All comparisons are made against Roborock’s previous models that do not include the specified features.
Roborock F25 Ultra
265mm*246mm*1096mm
Wet&Dry Vacuum Cleaner
316mm*353mm*1156mm
Vacuum Cleaner with Dock
1. Based on Roborock’s internal R&D records and available public information, Roborock was the first in the robot vacuum industry to mass-produce a wet & dry vacuum cleaner featuring both VaporFlow™ and WaveFlow™—technologies enabling steam and hot water cleaning modes simultaneously, officially launched in Q3 2025.
2. Based on Roborock’s internal R&D records and available public information, Roborock was the first in the robot vacuum industry to mass-produce a wet & dry vacuum cleaner featuring both VaporFlow™ and WaveFlow™—technologies enabling steam and hot water cleaning modes simultaneously, officially launched in Q3 2025.
3. Based on internal testing by SGS and the manufacturer. Actual performance may vary depending on environmental conditions.
4. Based on internal testing by the manufacturer. The stated 180°C/356°F refers to the steam temperature measured at the internal heater output, not at the steam outlet. Actual performance may vary depending on environmental conditions.
5. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
6. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under steam mode, over 99.99% of bacteria on the floor were effectively eliminated. Report No.: 704012501495-01. Actual performance may vary depending on environmental conditions.
7. Based on TÜV SÜD testing of pollen, cat dander, dog dander, and dust mite allergen under steam mode, over 99.9% of allergens on the floor were effectively removed. Report No.: 704012505041-00. Actual performance may vary depending on environmental conditions.
8. Based on TÜV SÜD testing, after operating the machine for 60 minutes and push and pull for 18,000 times on a solid wood floor, no blistering, bulging, or deformation occurred. Additionally, no visible scratches or color changes were detected. Report No.: 704012500497-01. Actual performance may vary depending on environmental conditions.
9. Based on TÜV SÜD testing, after operating the machine for 60 minutes on a solid wood floor, no blistering, bulging, or deformation occurred. No visible scratches or color changes were observed. Report No.: 704012500497-01. Actual performance may vary depending on environmental conditions.
10. Based on SGS testing and the Safety Data Sheet, the integrated FOF scale inhibition filter material is biologically inert and environmentally compliant.Under normal usage conditions, it presents no viable pathways for accidental ingestion, dermal contact, or ocular exposure. Water processed through the FOF system contains no detectable chemical contaminants. Actual performance may vary depending on environmental conditions.
11. Based on internal testing by the manufacturer, after simulating three-year usage of the machine, the scale inhibition rate is higher than 97.5%. Actual results may vary depending on home environment, cleanliness, cleaning habits, and other factors.
12. Based on internal testing by the manufacturer. The stated 86°C refers to the hot water temperature measured at the internal heater output, not at the water outlet. Actual performance may vary depending on environmental conditions.
13. Based on TÜV SÜD testing of hot pot oil under hot water mode, over 99.99% of the oily mess on the floor was effectively eliminated. Report No.: 704012500496-01. Actual performance may vary depending on environmental conditions.
14. Based on internal testing by the manufacturer according to IEC 62885-2:2021/5.11 standards. Actual performance may vary depending on environmental conditions.
16. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
17. Based on internal testing by the manufacturer in Auto mode with gentle suction setting. Actual performance may vary depending on environmental conditions.
18. Based on internal testing by the manufacturer, operating the machine in Auto mode with minimum suction power at a speed of 0.5 m/s. Actual results may vary depending on home environment, cleanliness, cleaning habits, and other factors.
19. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
20. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet long hair across all four operation modes under controlled testing conditions. Report No.: SHES250100116672. Actual performance may vary depending on environmental conditions.
21. Based on internal testing by the manufacturer. A full cleaning solution tank provides up to 30 days of use, assuming once-daily cleaning in a test environment. Actual results may vary depending on home environment, cleanliness, cleaning habits, and other factors.
22. Based on testing by Intertek Assuris, the Roborock floor cleaning solution is not classified as a risk for acute oral toxicity, skin irritation, corrosion, sensitization, or chronic toxicity when used under normal and foreseeable conditions. Report No.: SHJ1830015. Actual performance may vary depending on environmental conditions.
23. Based on internal testing by the manufacturer. The stated 180°C/356°F refers to the steam temperature measured at the internal heater output, not at the steam outlet. Actual performance may vary depending on environmental conditions.
24. Based on internal testing by the manufacturer. The stated 90°C/194℉ refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual performance may vary depending on environmental conditions.
25. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli during self-washing, over 99.99% of bacteria were effectively eliminated. Report No.: 704012501495-01. Actual performance may vary depending on environmental conditions.
26. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
27. Based on internal testing by the manufacturer, after 5 minutes of drying, the water content of the roller is less than 0.2g. Actual performance may vary depending on environmental conditions.
28. Based on internal testing by the manufacturer. Actual performance may vary depending on environmental conditions.
