Up to 13,000 Pa
HyperForce™ Suction Power1
Dual Anti-Tangle System
Three Levels of
Water Flow
PreciSense™ LiDAR
Navigation
Self-Emptying Dock
Flexible App Control
Impressive HyperForce™
Suction Power
Root Out Hair
From Crevices and Carpets
With an impressive suction power, this powerful system is built to lift hair and debris from floor crevices and deep within carpets.
Roborock Q7 Pro Max(+)
Roborock Q7 TF(+)
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Consistent Water
Flow Mopping
3 Levels
Water Flow Options
Detachable Mop Design
For Versatile Cleaning Needs
Anti Scale Design
Built-in nonhazardous3 descalers bag prevent scale formation and protect pipes from clogging for up to 3 years4.
Roborock Q7 TF
Roborock Q7 Pro Max+
Roborock Q7 TF
Experience hassle-free cleaning convenience with the RockDock® Plus. The large dust bag lets you clean for up to 7-9 weeks without emptying5, making it ideal for families with pets and reducing allergens. 6
Temporary Cleaning
Auto Boost on Carpet
High-Intensity Mopping
In DEEP+ mopping mode, movements slow down, and mopping paths are finely divided for a deep, thorough clean, helping to tackle stubborn dirt with enhanced slow-mop action.7
Cleans Along Floor Direction
Robot Vacuum
Robot Vacuum
1. Based on Roborock internal testing under Max+ mode with a full battery according to IEC 62885-2:2021/5.11 standards. The maximum suction power varies among different models. Actual results may vary depending on usage conditions.
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN25I41V 001. The pet hair anti-tangle rate is 0%, while short human hair (20 cm) anti-tangle rate is 0.063%. Actual results may vary depending on usage conditions.
