Roborock Qrevo 2 Pro
Designed for homes with carpets, pet hair, and everyday mess, the Roborock Qrevo 2 Pro brings together powerful suction, zero-tangle brushing, smarter carpet care, and wider edge coverage — all working together to keep your home cleaner with less to manage.
Experience true cleaning power with 25,000 Pa HyperForce™ suction. Whether on hard floors or carpets, it delivers strong pickup for everyday dust, crumbs, and embedded dirt.
Max Digital Motor Power¹
Hair Tangling²
Hair Removal⁵
Hair Tangling²
Up to
30% more
corner coverage³
1.85mm
Along the Edge⁷
Edge Coverage⁸
15mm
Mopping Module Lifting⁹
200RPM
Maximum Rotating Speed¹⁰
1.85mm
Along the Edge⁷
Edge Coverage⁸
15mm
200RPM
stain removal rate¹¹
High-Temperature Mop Self-Cleaning
Up to 75°C (167°F) high-temperature¹² mop self-cleaning. Helps reduce greasy buildup on mops for a more hygienic clean in kitchens and dining areas.
Warm Air Drying
45°C (113°F) warm air drying¹³ with 45dB low drying noise¹⁴. Helps reduce odors and keeps mops and the dock more hygienic between sessions.
Auto Tank Refilling
Refills for you, so mopping doesn't dry out mid-run. No more dragging a dry mop across the floor.
Roborock APP
The Brain Behind Every Clean
After room types are selected, Roborock SmartPlan™ 3.0 learns your cleaning habits and automatically tailors the optimal cleaning strategy for each room, boosting suction where needed, rewashing the mop when necessary, and lowering power to reduce noise during Do-Not-Disturb periods.
Everyday Features
Specs
352*350*96.6 mm
402*494*450 mm
2. Based on internal testing, the hair tangling rate is 0% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively, across all Vacuum Only Modes under controlled testing conditions. Actual performance may vary depending or environmental conditions.
3. Based on internal testing by the manufacturer. Corner coverage is calculated within a 50 × 50 mm corner area based on the measured distance from the 45° corner point to the brush cleaning arc; uncovered area is defined by the two wall edges and the cleaning arc.
5. Based on internal testing, the hair removal rate 100% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively, across all five Vacuum Only Modes under controlled testing conditions. Actual performance may vary depending on environmental conditions.
9. Based on internal testing carried out by the manufacturer, the mopping modules can be lifted up to 15 mm. Actual results may vary depending on environmerhtal factors.
12. Based on internal testing conducted by the manufacturer. The stated 75°C refers to the temperature measured at the internal heater output, not the temperature of the mop itself. Actual performance may vary depending on environmental coonditions.
13. Based on internal testing carried out by the manufacturer the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
