Roborock Qrevo Slim
Slim. Smart. Spotless.
8.2cm Ultra-Slim Design
Slim and Spotless, Everywhere
Roborock Qrevo Slim packs a powerful punch in a sleek, low-profile 8.2cm frame, designed to conquer hard-to-reach areas. It seamlessly glides under sofas, beds, and other low-clearance areas with its advanced locating and mapping capabilities, providing a truly complete cleaning experience.
StarSight™ Autonomous System
Industry-First Dual Light Solid-State LiDAR1
Pioneering Navigation System
Unlock Next-Gen 3D Sensing
As Roborock’s latest cutting-edge innovation, the sophisticated 3D Time-of-Flight (ToF) system provides a comprehensive 3D understanding of the surroundings, enabling precise navigation with pinpoint precision and accurate mapping, even in challenging areas around suspended cabinets and thin-legged furniture.
21x
Improved Sampling Frequency2
Enhanced Precision
The 3D sensing technology captures detailed information, including depth and height, ensuring accurate locating and mapping performance even in tricky areas.
Comprehensive Capabilities
The robot seamlessly navigates through your home and detects obstacles simultaneously.
Improved Coverage
The compact design empowers the robot to access previously hard-to-reach areas, such as under furniture, for improved cleaning coverage.
Advanced Obstacle Recognition
Roam Without a Hitch
Powered by 3D sensors that capture precise outlines of obstacles and an RGB camera for visual recognition, the robot reacts promptly to unexpected obstacles and small items. This advanced intelligence allows it to maneuver through your home without any hassle.
Explore StarSight™ Autonomous System
FlexiArm™ Side Brush and Mop
Leave Dirt Nowhere to Hide
The FlexiArm™ technology empowers double robotic arms for the side brush and the mop to expertly sweep dirt from corners, edges, and under furniture. The flexible system ensures comprehensive cleaning coverage, eliminating blind spots for a meticulous whole-home clean.
DuoRoller™ Riser Brush
Double the Power,
Double the Clean
The dual counter-rotating all-rubber brushes and 11,000 Pa suction power make the Roborock Qrevo Slim an outstanding cleaning force. It conquers dirt, hair, and debris across various floor types like hardwood, tile, and carpets for a pristine, flawless finish.
99%
Hair Pick-up Rate on Carpets7
Tailored for Easy Carpet Maintenance
Get better carpet care with a 99% hair pick-up rate using the Roborock Carpet Boost+ system.
99%
Carpet Boost
Deep Carpet Cleaning
Vacuum Carpet First
Dual Spinning Mops
Tackle Tough Stains and Grime
Elevate your cleaning routine with the dual spinning mops. Engineered to glide effortlessly across your floors, the mops apply constant pressure and humidity for a flawless shine.
Liftable Brushes and Mops
Designed for a Perfect Clean
The automatic lift capabilities for the brushes and mops optimize performance for different tasks and prevent stains after cleanup.
DirTect® Technology
Adaptive Cleaning Intelligence
Dirt doesn’t stand a chance as the robot adapts its cleaning strategy based on the dirt type. Heavy dust? It cranks up the suction. Stubborn stains? It mops with increased water flow.10
Multifunctional Dock 3.0
8-in-1 Hands-Free Maintenance
Hot Water Mop Washing
Intelligent Dirt Detection
Self-Cleaning
Warm Air
Drying
Auto Tank
Refilling
Detachable Base
Faster Charging & Off-Peak Charging
The heated water effectively dissolves greasy stains and removes over 99.9% of bacteria from the mops, leaving your floors in dining areas and kitchen hygienically clean with minimal effort.
99.9%
Bacterial Removal Rate11
For Re-Wash
During mop washing, the system continuously monitors the dirt level to adjust the wash duration, guaranteeing your mops are thoroughly cleaned.
For Re-Mop
For floors with stubborn, heavy soiling, the dock automatically triggers an additional mopping pass to ensure a perfect clean.*
*The automatic re-mopping feature needs to be activated manually in the Roborock App.
Dock Self-Cleaning
With the motor-driven cleaning module, the dock base is cleaned effectively by rotating scrapers, eliminating the need for manual maintenance. All self-cleaning module accessories and the dock base itself are fully detachable for easy washing when needed.
Say “Hello Rocky” for Help
Just say the words “Hello Rocky” to kick off cleaning tasks and access more capabilities. Your voice-controlled companion is always ready to help, no network is required.
Video Call & Cruise
Whether you need to check in on your furry friends, schedule on-demand cruises, or manually control the robot’s patrols, it’s all just a tap away.
Video Call & Cruise
Pet and Pet Supply Recognition
It stops its main brush and moves aside in advance when approaching your beloved pets to avoid frightening them. And it will boost suction when cleaning around pet supplies for a thorough clean.14
Pet Snaps
Capture those adorable moments of your pets with Roborock Qrevo Slim. While tidying up your home, it can snap precious pics of your pets, readily available for you to download.
Search for the Pet
Are you concerned about your purring pal home alone? With a tap on the App, the robot will roam around your home to find your pet.
Elevate Smart Living with Matter Protocol
Embrace the power of Matter standard through the Roborock Qrevo Slim, leading you to boundless smart home possibilities. Say goodbye to the frustrations of limited compatibility as you effortlessly take control of your robot vacuum and other compatible devices. Discover the true convenience of a fully integrated smart home.
| Roborock Qrevo Slim | Roborock Qrevo Master |
8.2cm Robot Height |
10.3cm Robot Height |
StarSight™ Autonomous System |
PreciSense™ LiDAR Navigation System |
Reactive AI Obstacle Recognition |
FlexiArm™ Side Brush |
FlexiArm™ Edge Mop |
DuoRoller™ Riser Brush |
11,000 Pa HyperForce™ Suction |
10,000 Pa HyperForce™ Suction |
Multifunctional Dock 3.0 |
Intelligent Voice Assistant |
8.2cm Robot Height
FlexiArm™ Edge Mop
10.3cm Robot Height
FlexiArm™ Edge Mop
