Roborock H5
Feel the power,
not the weight
Roborock H5
Feel the power,
not the weight
158 AW
  • True Suction
1.55 kg
  • Lightweight
  • 99.997%
    5-Stage Filtration
  • 9-Cyclone Dust Separation
  • Up to 60min Run Time
  • Auto Boost on Carpet
True power.
Deep clean.
Motor-rated power isn't equivalent to actual suction power due to losses through the vacuum filter and cyclone. The Roborock H5 delivers up to 158 AW of whole-machine suction power, certified by TÜV Rheinland, ideal for deep cleaning tasks.
Up to 158AW whole-machine suction1
Lightweight for everyday convenience.
1.55 kg vacuum body
1.82 kg with Motorized Mini Brush
What goes into the vacuum,
stays in the vacuum.
With a 5-stage filtration system including a HEPA filter, Roborock H5 is able to capture up to 99.997% of micro dust as small as 0.3 microns.
Up to 99.997% retention of microscopic dust2
Designed for minimal clogging.
The meticulously calculated and simulated 9-cone cyclone separation system generates a strong centrifugal force that settles dust, debris, and other large particles into the dustbin, ensuring that air passes through the filter unobstructed.
9-cyclone dust separation system
Vacuum on and on,
and on.
With a power-dense battery, Roborock H5 provides up to 60 minutes of non-stop vacuuming per charge.3
Up to 60 minutes battery run time
Multi-surface brush for floors and carpets. Roborock H5 combines soft velvet bristles with a nylon brush head, ensuring effective cleaning for both floors and carpets.4 This is a image This is a image
Auto-Boost on Carpet In standard mode, when the main brush is on the carpet, it automatically activates carpet boost, achieving better cleanliness for removing dust and hair from the carpet.5
50% motor power increase6
5000 times/min patting frequency to remove dust mite7
2-In-1 Crevice Brush
Effortlessly switch from brushing your car to vacuuming hard-to-reach corners with this 2-in-1 crevice brush.
5-step noise control.
The multi-layer noise reduction system effectively absorbs vibrations and dampens high-frequency sharp noises, ensuring minimal disturbance while vacuuming.
Down to 68.9 db(A) sound level8
One click.
Say goodbye to dirt.
Empty your vacuum in just one click. Keep it fresh.
Or you can just
pull, seal and dispose.
card
Pull-to-Seal When detaching the dust bag, it automatically seals to prevent dust from spilling out.
card
Transparent Window Roborock H5 dust bag features a transparent window, so you know when to empty it.
Washable cyclone and filters.
The front filter, rear filter, and multi-cyclone assembly are detachable and washable, helping to maintain long-term performance and cleanliness.
card card
Store with ease,
charge with peace.
card
Wall-mounted charging dock Store all your clean heads neatly on the wall-mounted charging dock.
card
Shockproof charging design For safety reasons, the electrodes are disconnected when the vacuum cleaner is not on the charging dock, even if the charger cable is still plugged in.
Roborock H5
Product Dimension
1135*250*243 mm
card
STAY TUNED
** The cyclone assembly of the Roborock H5 can be replaced with a dust bag. For detailed replacement instructions, please refer to the user manual.
1. Tested by TÜV Rheinland based on IEC 62885-4:2020/5.8 standards. Tested without accessories, in Max mode, and with testing an equipment diameter of 10mm. Actual results may vary depending on usage conditions.
2. Tested by TÜV Rheinland based on IEC 62885-4:2020/5.11 standards. Tested in Max mode for capturing particles of 0.3-10 microns. Actual results may vary depending on usage conditions.
3. Based on Roborock internal test with 2-in-1 Crevice Brush in Eco mode. Actual battery life may vary depending on usage conditions.
4. The Multi-surface Brush can only be used on carpets with a pile height of less than 2.5 cm (0.98 inches). Actual performance may vary depending on usage conditions.
5. Carpet Boost is only available on Standard mode. This function might not trigger on smooth mats or carpets with shorter piles. Actual results may vary depending on usage conditions.
6. Based on Roborock internal test in Standard mode. Actual power increase may vary depending on usage conditions.
7. Based on Roborock internal test in Standard mode. Motorized Mini Brush has a rotation speed of up to 2500rpm. With two nylon bristle strips on the brush, the Motorized Mini Brush is able to pat 5000 times per minute. Actual results may vary depending on usage conditions.
8. Based on Roborock internal test referencing GB/T4214.2-2020 standards. Sound level in Eco mode as low as 68.9dB(A). Actual results may vary depending on usage conditions.
