Flex Your Clean
Introducing Roborock Flexi Pro - the ultimate flexible solution for all your cleaning needs. Leveraging Roborock's vast expertise in home cleaning, it excels in handling wet and dry messes, delivering edge-to-edge cleaning performance, and effortlessly navigating beneath low-profile furniture. Enhanced with smart features like adaptive cleaning and self-cleaning, plus app compatibility, it offers effortless and worry-free operation.
Edge-to-Edge Cleaning: No Corner Left Untouched
Reaches Everywhere, Even Under Low Furniture
SlideTech Automated Wheels: Built for a Smooth Operation
DirTect®: Automatically Adapts Cleaning and Self-Cleaning
Intelligent App and Voice Alerts for a Convenient Clean
One-Stroke Wet & Dry Cleaning
Cleaning should be efficient, so your precious time is spent on more important matters. From cooking mess to your little ones’ playful chaos, Roborock Flexi Pro has it all covered with a single stroke. With 17,000 Pa1 suction power, it’s ensured to meet your high standards of home cleanliness and tidiness.
With DirTect® adaptive cleaning capability, Roborock Flexi Pro adjusts its cleaning power according to dirt levels on the floor, ensuring a thorough and time-saving cleaning experience. When self-cleaning at the base, DirTect® checks if your roller has been cleaned effectively and switches to Deep Clean mode if it detects that the roller is still dirty after washing.
Always Clean, Always Fresh
Incorporating Roborock’s automatic self-drying & cleaning technology for wet-dry vacuums, Roborock Flexi Pro self-cleans with a roller scrape and water spray module, ensuring a sparkling clean result while cleaning your floor.
70°C
60°C
Hot Water Self-cleaning
5 min
Auto Brush-Drying
99.9%4
Bacteria Removal Rate
With Roborock Flexi Pro’s hot water self-cleaning and hot air self-drying feature, the roller is being scraped and washed in two directions with 60℃ (140℉) hot water, complemented by the flow of 70°C heated air, guaranteeing a hygiene and odor-free experience in 5 min.
15cm5
Flexibility is the Key
Roborock Flexi Pro features FlatReach™ technology for thorough cleaning under low furniture. Equipped with a powerful headlight, it leaves no place for dirt to hide, ensuring a spotless clean.
Push, Pull, Perfection
Powered by SlideTech’s automatic adaptive wheels, Roborock Flexi Pro responds and counter-spins to the roller's speed, making vacuum operation easier for pushing and pulling.
Roborock Flexi Pro easily reaches edges and corners with side margins of less than 1 mm6.
All in Reach, All in Sound
With an LED screen accessible at your fingertips, monitoring modes and status becomes effortless. Roborock Flexi Pro also provides real-time updates and operational reminders through convenient voice alerts.
Auto
Cleaning rollers
Empty the dirty water tank
Effortless Clean, Now Elevated with Intelligence
RoomTemperature
Warm
Hot
Maintenance
50%
75%
Start Time
16: 47
Repeat
Weekdays
Your Cleaning, Your Way
The Roborock App tailors the cleaning experience to your precise requirements. Unlock a range of intelligent features for customization, including a self-drying and cleaning timer, water temperature adjustment, suction power control, and more.
Long-Lasting Cleanups
With a substantial 50 min battery life, it delivers prolonged cleaning sessions without interruption, enabling an extensive cleaning coverage (420 sqm/ 4520 sqft7) before requiring recharging.
730ml
Clean Tank size
50min8
Battery Life
450ml
Dirty Tank Size
Cleaning That Lasts
| Roborock Flexi Pro | Roborock Flexi Lite |
Up to 50 min Battery Life |
Up to 40 min Battery Life |
5 min Auto Brush-Drying |
60 min Auto Brush-Drying |
5kg (11lbs) |
4kg (8.8lbs) |
730 ml Clean Water Tank Size |
620 ml Clean Water Tank Size |
450 ml Dirty Tank Size |
400 ml Dirty Tank Size |
Dual Sides Edge Cleaning |
Single Side Edge Cleaning |
Hot Air Self-Drying |
Hot Water Self-Washing |
Standard Self-Washing |
SlideTech Adaptive Wheels |
Built-in Headlight |
App Compatibility |
5kg (11lbs)
Hot Air Self-Drying
Built-in Headlight
App Compatibility
4kg (8.8lbs)
Hot Air Self-Drying
2. Based on internal testing, the water in the clean water tank can be heated up to 60℃ at standard room temperature. The actual temperature will vary due to environmental factors.
3. Based on internal testing. The actual temperature will vary due to environmental factors.
4. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.9% of bacteria on the roller are effectively removed. Test Report number: 244555550b3 001. Actual results may vary according to the home environment.
6. Based on internal testing. Actual results may vary depending on environmental factors.
7. Based on internal testing carried out by the manufacturer under ECO mode.
8. Based on internal testing carried out by the manufacturer under ECO mode.
