Series
Clean with Double Simplicity.
q7plus
Experience a revolution in cleaning with the DuoRoller™ Brush. Coupled with an impressive 5,500 Pa suction and smart navigation, the Q5 Pro delivers an effortless cleaning experience.
2x
All-Rubber Brushes
20%
Hair Pick-up Rate1
Double Rollers for
Double the Power
Introducing the DuoRoller™ Brush, the latest in Roborock's cleaning technology, designed to enhance vacuuming performance on carpets and ensure fewer hair tangles to provide a hassle-free cleaning.
2x
All-Rubber Brushes
20%
Hair Pick-up Rate1
Impressive 5,500 Pa
Suction Power
HyperForce™ suction power has been upgraded to 5,500 Pa2, allowing Q5 Pro to easily remove dirt and pet hair from different types of floors, leaving you with a spotless living space every time.
Seamless Floor Cleaning
Larger Dustbin for
Longer Pet Hair
Clean On and On
240 min
Maximum Runtime3
350 sqm (3767 sqft)
Maximum Vacuuming Area3
Remove Dust You Hardly See
Detachable Design
for Versatile Cleaning Needs
Clean As You Wish
Custom Cleaning Routine
Fast Cleaning
Speak to Command
Handles Your Dirty Work
7 Weeks
*RockDock® Plus is only available with the Roborock Q5 Pro+.
  • Customizable App Features
  • Sensient™ Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Q5 Pro Dimensions
Robot vacuum
350*353*96.5 mm
305*440*448 mm
STAY TUNED
